Dome light
DE3175
DE3175LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Postby
tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.htmlMon Jan 24, 2011 9:57 pm
Do you have HID stock or are yours yellowish in color? If yellowish then you would need a conversion kit. If you have HID stock, then you just need bulbs. IMO, you should stay at 6000K. 8000K will look too blue, and you will have visibility issues as well as possible law enforcement harrassment.
Postby
audtatious »
https://forums.nicoclub.com/audtatious-u2438.htmlMon Jan 24, 2011 10:16 pm
Daniel G wrote:Next time click the flashing red button on your right.
DG
If this were a common question it would be easy to find. There is not a whole lot of repetitive threads on here so there's no real reason to post "search for it" responses.
