what size spacer with advan sa3 +32 pignose hatch
silviaS13lover
Car: yellow llama onevia
ok so ive been trying to find a spacer that will make my +32 advans flush or stick out a tad from the fenders. any help would be apprieciated. thanks
Broadfield
Car: 1992 240sx
Dude, we kind of need to know the width of the wheel?????
silviaS13lover
o ****. lol its a 16x7. sorry
Broadfield
Car: 1992 240sx
You need to push those suckers out 25mm to get them "flush". Even more if you want them stick out and run a stretched tire.
This is for the rear of course.
silviaS13lover
ok so a 25mm on the rear. what on the front?
Broadfield
Car: 1992 240sx
About 15-20mm
silviaS13lover
ok so 15 alittle inside the fender and 20 alittle outside fender? thanks
Broadfield
Car: 1992 240sx
Of course the best thing to do is bolt them up and measure from the face of the wheel to the face of your fender/quarter. If you like the flush wheel look then go with that measurement for your spacer. If you want them to stick out and run a stretched tire, then add a little to your measurement.
Emperor_Tha
Broadfield wrote:About 15-20mm
Probably wheel spacer adaptor?
Any recommendation brand or site on adaptor spacer for 4 lugs?
Mauibuilt Guy
Car: 1997 240SX SE
H&R track and wheel spacers or KICS. H&R are going to be cheaper and already has a hubcentric ring manufactured on the spacer.
yokota180sx
Car: 1997 Stagea RS4, r34 front
50mm all aroundmaybe more
