Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sun Feb 18, 2007 4:50 pm
Read the FAQ. YOu can keep asking any one of our members if something will fit.,..but without knowing the offset of the wheels you are refering to, no one can tell you. A 9.5" wheel -can- fit on the bakc of an S13, but generaly will require fender rolling in order to clear without problems. Again, we need to know the offset before ANYONE could tell you...everything you get otherwise is just conjecture and estimations.
That said, a 235/40/18 and 265/35/18 would work fine on those wheel sizes. don't vary your F/R tire sizes too much (unless you just want the look and don't care about what happens to your handling) if you're going to have a balanced chassis...otherwise you can end up having much more griop in the back, and having to adjust your suspension to compensate.
-Chet
