C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Feb 19, 2008 7:54 pm
Given that the space is limited, I'd get the biggest that would fit and that you can afford. Do consider quality as well. The intercooler is not only a heat exchanger, it also acts as a heat sink allowing you to absorb some of the more extended boost periods and shedding the heat at a faster overall rate than a smaller version of the same intercooler. I wouldn't worry too much about the extra volume a larger intercooler will provide. Given the limited space available for a front mount and that an intercooler's internal volume would only be at about 50% of the overall volume (at most), any increases in volume would be pretty negligible.
