What size HG for a turbo rb25DE
Iknowthefuture
Car: 2000 Pontiac Trans Am
I have a de that I am going to throw a turbo on. as of now its on the engine stand waiting on arp head studs. i have the stock replacement de/det HG from the rb25 gasket kit. I found that the DE has 10:1 compression and IIRC the HG is .051 thick and 86mm bore. the rotating assembly is still stock and hasn't been rebuilt with 60,000 miles on the ODO. I just want 300-350 if I can get that now as a DD, until I rebuild the motor.
Which gasket and what thickness should I go with?
9:1 ftw?
Could I reach my goal with the oem HG, copper spray, and 93 oct?
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
if you have no luck here, try this question in the RB specific forrum...
rb20-rb25-rb26-forum.html
Gabes13
Car: rb20det s13
An oem gasket could handle 350 easily. There are setups with 400+ on oem.
Iknowthefuture
Gabes13 wrote:An oem gasket could handle 350 easily. There are setups with 400+ on oem.
the rb25de has a point higher of compression than the det... i know that the gasket can physically hold it, i'm worried about detonation on pump gas.
