centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Mar 07, 2016 6:01 pm
So, you're probably using a normal timing light. You can't see your RPMS and timing at the same time nor do you have the accuracy of a data logger. So you don't know what exact degree you're on at what exact RPM. You can hit the throttle and watch the timing bounce around on your crank pully, but it's not useful information. That would be a normal situation. My KA does that. It also changes based on the load. So, mine looks like it drops degrees as I increase throttle and RPMs, but then I just hold it there and it stabalizes a bit and then increases in degrees. Neat to look at, but useful? I don't know. AFAIK you set your timing and RPMs at Idle per the FSM and let the computer do the rest. So, back to the FSM. Did you get your car to idle at 800 rpms and 15 degrees?
