i have a competition clutch, stage 5 clutch with upgraded pressure plate, stock driveshaft, stock vlsd , new nankang 255/40/17, kyb shock and eibach lowering springs. the reason why i have such a upgraded clutch is because im very close to having all the things i need for my 400hp build, and i put things on that i dont need to get tuned for. so needless to say, my clutch has a bite from hellnzmoman wrote:I don't have that setup but with those numbers you can get low 13's pretty easy. the 1/4 times will depend on the rear end, and other drive train mods. clutch, driveshaft,lsdtiresrear suspension setupif you post that you can get a more accurate assessment on 1/4 possibilities
first off, who the hell are you ?and by the way.............you have fun with your lil t28, all i have left to get is the manifold and its on like donking kongmistamacadamian wrote:who cares that **** is slow, my buddies e36 m3 stays with me on 10lbs even though he has some bolt ons and im on a t28.
migsk8 wrote:IF YOU DO NOT OWN A SET UP LIKE THIS OR KNOW SOMEONE, DO NOT POST!
i have more than is pictured above, and i can blow my motor if i please, i never asked for a opinion from you or anything about my setup, so if you would please stop harrassin me it would be the more mature thing to do. and FBI is not in here because he can actally read and he does not have the required set up to post in here. and neither do youjr_ss wrote:First off, you're an idiot for running a stock ECU with 9:1 comp ratio ... I bet youre running lean as hell. Second off, you have a bigger turbo, and an ebay manifold, I don't see anything else to support those mods except the PFC... A knock off greddy oil pan and 2 gauges aren't going to get you moving any faster. Not to mention you aren't going to make any power on 370cc's... Wait wait, I see rocker arm stopper's, watch out people he plans to bounce off the rev limiter... Grow up and stop making stupid posts. You only make yourself look like a moron more and more. Where's FBI when you need him.
And I posted because of this....
why are you running 9:1 ?migsk8 wrote:
ok so you are telling me my stock vlsd will go out at 240hp ????? wtf, i've never herd of that. no joke. but about the tramp thing, he doubted me so i proved him wrong and he shut up pretty quickly.TRBOMOFO wrote:why are you running 9:1 ? yeah i would say that the stock LSD is going to go out on ya if you try to take it to the strip i ripped mine out and i have "basically" the same setup and i had to get a new oni had 240 RWHP and 235 ft lbs but i was running 14 psii would say though if you stay at 7 psi i would not expect more then 220and thats with some sdvanced timing adjustmentsoh about the picture^^^^^tramp_drift240 lives near my vicinity i will have to give him some help if this is turning into a war
i might have to add i was not nice to mine and i romped and tried to learn to drift on one so that help with the killing of that LSDmigsk8 wrote:ok so you are telling me my stock vlsd will go out at 240hp ????? wtf, i've never herd of that. no joke. but about the tramp thing, he doubted me so i proved him wrong and he shut up pretty quickly.
