WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Mon Apr 11, 2005 7:23 pm
The safc is a fine tuning device for the money.
The MSD BTM does exactly what you need it to do. You only need to retard timing when your under boost, so it only pulls timing when your under boost, the NA mpas will work great for every other occasion.
Timing can be retarded via a dial anywhere from 0-3 degree's per lb of boost. Usually .5 is best.
Get a MSD Knock Meter if you'd like to measure knock. The stethescope will not work, there is to much ambient noise.
Knock is read by the ECU, the ecu pulls timing out under knock conditions, but not enough to keep you from blowing up your motor. The ecu may already be pulling out timing, you won't know it unless you have a datalogger or scanner.
