dustyk »
https://forums.nicoclub.com/dustyk-u13031.html
Tue Aug 15, 2006 9:41 am
I think the temperature readings that you get from aftermarket water temp gauge differs substantially depending on where you place the sensor. I run an aftermarket probe in the upper radiator pipe since at this point is where the hot coolant comes out of the motor. My friend has a nismo one that goes where the stock temperature gauge is and his gauge reads a lot lower than mine since the stock temp gauge is located right where the coolant comes back after passing through the radiator.
