ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Jul 01, 2011 5:52 pm
Remember that big air/water heat exchanger up front sees a temperature close to 200F and if you are still only the cooling fan brings in enough air. Moving varies and faster you go, more RPM more combustion, more heat produced more cooling air. In your area 100 degrees is not unusual so you have a 100 degree cooling effect at most and that is at 100%. Our exchangers are not 100%, but they are big, with the temperatures you are getting you are OK.
The best coolant is the cheapest, water, but it has many problems. So we mix glycol with it. You have little need for freezing so you can benefit from water. But you still need anti-freeze because of the rust inhibitors.
Instead of 50/50 try experimenting with it, try 40 % glycol and 60% pure water, you should see better cooling temperatures.
I'm stuck in central Ontario with -40F winter temperatures so my mixture is about 40% water, 60 % glycol with a -50F freeze rating and a ridiculously high boiling point.
If I lived in the Sun belt it would be pure water rust preventative and some anti-freeze to safely get me over the expected cold snaps. It takes time for even water to form ice crystals, but do keep your vehicle safe from freezing.
And I have not discussed the high temperatures that the transmission inputs to the radiator. So when you see a 90 F ambient and about 170-190 F temperature you are doing good.
