JESTER »
https://forums.nicoclub.com/jester-u253.html
Sun Aug 24, 2003 3:28 pm
Okay, here I go.
First you should do suspension, brakes, and rims.
Second, here is the answer to your turbo question. You can do a junkyard kit for under $2000. more like $1500 if you know where to get the parts. Check this thread out. Do a few more searches, and you should be able to come up with some additional info. I hope.
http://www.nissaninfiniticlub....xy240
Nitrous? If you learn about it, and have a professional install a good quality system, you would be fine. It is a good bang for the buck. Just do a little research on nitrous so you know what you are getting into. I bought a book, "Nitrous systems for sport compact cars," or something like that. Check Barnes and Noble in the automotive section.
PS If you are gonna do Nitrous or Turbo, get your engine compression tested, just top make sure it is in good shape.
