What should I use to clean my injectors?
AZ94Q
Could you guys give me some good recommendations on fuel injector cleaners. I think mine may be a little clogged. I have also moved to Mobil 1 10w-40. Are there any other specific fluids you guys would recommend, to keep the Q in tip top shape.
Mayhem_J30
Car: Ummm...My Car
sythetic everything for other fluids.
i think it's agreed upon around here that your typical FI cleaner is only a mild preventive maintenance step. For a real cleaning you'll require a rail flush with some BG cleaner. After that you should stick with regular FI cleaner every 3000 miles and use a good premium fuel like Chevron w/Techron to help keep those injectors clean.
Q45tech
