what should I use for clutch/flywheel on 600hp VG30ET?
Discuss topics related to the VG and VE series engines.
Speeddoctor
Car: Nissans, Infinitis, datsuns, motorsickles,
NICO founder April 22, 2000
Hey guys I may go to a 5 speed on my M30 VG30ET. What would be the cheapest clutch/flywheel combo that could take 600 hp? SD
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Race only or planning on street driving as well?
If race only you could use something like a high stage SPEC clutch. The stage 3 handles 515 torque and they go up to stage 5 though they start getting very stiff and less streetable.
ACT is a good route and I hear South Bend Clutches makes some very good ones as well.
For a good street clutch that'll handle a ton of power, you could spend a good deal of money on a OS Giken multiplate clutch. That would hold the ultimate amount of power and still be very, very streetable. Much more expensive though.
Speeddoctor
thanks for the reply! Yeah, I'd like to stay away from the cost of a multiplate. Been there done that on my R33. I'll be using the car mostly on the street. What would be the cost on the stage 3 and where would you suggest I get it? SD
mtcookson
1992 Iinfiniti Q45
and much much more
I got mine from http://www.nipponpower.com. For some reason (not sure if this holds for all Z31 clutches) but the earlier 240 mm clutch setup has a higher torque capacity rating than the later 250 mm Turbo clutches.
The pedal feel is definitely stiffer than stock but it'll definitely hold some power. I did notice some slipping while cruising after driving for a few hours but now I know that its likely the pedal adjustment. I need to adjust the pedal a bit to fix that so if you get that clutch (or any clutch that may do the same) that'll likely be the solution.
You may also check out South Bend Clutch (www.dxdracingclutches.com). Their stage 3 holds as much torque as the SPEC stage 3 however it is a full face clutch instead of a puck design, which I would think would be quite nice. Prices are very similar.
SPEC is one of our sponsors, and they'd take good care of you Doc.
Lemme know if you need me to place a call.
Speeddoctor
Thanks guys! Sounds like the spec is the way to go.....Greg, I'll be in touch...Rex BTW Mr. MT, I like your collection! Good taste. What have you done to the Z31?
mtcookson
1992 Iinfiniti Q45
and much much more
So far, I've just been making it run good. One of the previous owners wasn't so good to it an pretty much blew the original engine so I dropped in an 85 Maxima engine and swapped the turbo setup over. 9:1 compression with the turbo setup makes for a very fun car.
I'm still deciding if I want to keep it or not but if I do I'll do the basic turbo, fuel, and intercooler upgrades for a fun street car.
Speeddoctor
Ahh, very cool, it is great that you are preserving the car...good goin!
ttinfinitiM30
Car: infiniti M30
sousay u got 600 hp. what kind of upgrades have u done to get that?
Return to “VG30 / VE30 Forum”
