What should I do with a cheap budge it?
ybot13
Car: 1990 nissan 240sx
rebuild my ka24e, bore the heads add cold air intake, header, high flow cat, exhaust system, short throw shifter, upgrade radiator clutch and flywheel. or should I turbo my ka24e, ka24de swap and turbo it, or sr20det swap.
Dunky Kong
Car: 89' SR20 240sx
It all depends how much your willing to spend with a cheap budget..do your research man cause the things your talking about are 3K plus!!!
ybot13
should i just keep my ka24e naturally aspirated or go with some sort of turboed engine?
Dunky Kong
Car: 89' SR20 240sx
I was going to turbo my single but it was going to cost just as much as swapping so i swapped for an SR it is up to you its your car and engine and your budget like i said before look at spending 3K+ especially for a SR cause you have to do a little bit more wiring because of the single cam to dual cam swap and you have to get a new gauge cluster!!
SeVa-S13
Car: '05 GTO 6spd
I suggest taking pride in your own vehicle enough to take the time to do the proper research and make a decision for yourself.
Dunky Kong
Car: 89' SR20 240sx
StylesCD
ybot13 wrote:rebuild my ka24e, bore the heads add cold air intake, header, high flow cat, exhaust system, short throw shifter, upgrade radiator clutch and flywheel. or should I turbo my ka24e, ka24de swap and turbo it, or sr20det swap.
the major difference between a DE and an E in terms of turboed power output hits once you're in the 350+ HP range. Until then either engine is fine. I'd say stick with that KA24E you have and get a junkyard Holset from some old dodge (HX35 or H1C) and rebuild it, it'll save you tons of money and perform better than any T3/T4 (the HX35 mounts right up unto a T3/T4 turbo mount)
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
all out or nothing. by your wishlist, i think the simplicity of sr swap would be best for you. you never mentioned anything about tuning the ka-t which leads me to think you havent done your homework
jump on the wagon and start saving, i dont think you are ready for the fail of your first kat.
1) Fix the rust.
2) Get it running the way it did when new.
3) Look up the word "budget".
(Sorry, had to pimp ya on that one... I read the thread title and was like, "No...he meant to do that...Yeah... totally." )
Welcome aboard - See #1 and #2 above.
