what should i do to flush my radiator.?
topairhead
Car: 180sx
any tutoriols any one be specific please?im going to do this 2morow i just want to make sure of everything before i do it.i already read on how to maintain my coolant system in "how to" but i want to make sure please i just bought a new radiator cap and thermostat.thanks.
vancouverbc
Car: 1991 240sx
zerothread/219519
Im working on a tutorial in the above thread. the first tutorial is for water pump replacement.
If you have access to hose you can use that to supply clean water while engine is running when you are flushing.
Dont forget the plug on the engine block in addition to rad plug.
Click twice on pics for large pic.
topairhead
Car: 180sx
thanks brosince im a noob to this stuff i dont know wat this meansplease bare wit me
"If you have access to hose you can use that to supply clean water while engine is running when you are flushing.
Dont forget the plug on the engine block in addition to rad plug."???????
vancouverbc
Car: 1991 240sx
Read the tutorial in the other thread. Its not that simple a procedure. There is a picture of the second drain plug. Hose refers to garden hose to supply water to radiator during flushing. The hose is not necessary but makes things easier.
topairhead
Car: 180sx
ok thanks well hopefully i can do this properly since its my 1st timeany things i should know like so i wont mess up anything??
Grim_Fandango
Car: 1990 200sx
hmm
qksilver1
Car: 1996 240SXSE 5sp Pearl White w/leather interior
Just make sure you get rid of the old fluids, just put them in a closed container. If you have any pets keep them away from Antifreeze it will kill them.
