What should i do to fill in the HUD hole for my dash.
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
hapaboi39
Car: 93 NISSAN 240SX COUPE
I just swapped my gauge cluster from HUD digital to an analog one.It works great!!!! However i know have this gaping hole where the HUD display used to be on the top of my dash. I was thinking about putting a gauge of some type to fill in the space.Have you guys had a similar experience. And if so what did you do about it?
Thanks!
hapaboi39
BUMP
Anyone else able to fill in the goofy space left by a non-working HUD????Holla atcha BOI!
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
you could get a piece of vinyl to glue over it, get a piece of plexi or abs plastic to cut for that slot, you could do a lot of things, but unless you take the dash off and recover the whole thing, then it's not going to look that good, but if you take enough time to put something over it, it won't look bad!
hope that helps!
-Dan
hapaboi39
thanks for tha advice Dan.
Katapl
Car: 91' R32 Sedan
I seen someone that had their boost controller actually sitting in there. It didn't look amazing, but it looked pretty good as a filler. That's probably what I would have done.
hapaboi39
That would be fly if i had a turbo but since i dont it would just look poser-ish....
But thanks for tha suggestion.
penpen-commander
just leave the hud unit there unplugged and secured.
or swap to non-hud dash.
Return to “Interiors”
