2ndnissan »
https://forums.nicoclub.com/2ndnissan-u80332.html
Sun Apr 12, 2009 9:30 am
Oil change for sure. Change diff fluid and trans fluid. Get new belts and hoses if any problems with those. New tires if it needs them. Check the ball joints,tie rod ends(I just changed these on mine..they can get really worn and boots were torn).Change out any bulbs that are burned out.,,,tag,dash,turn signals. Catch any rust early.Check injectors to see if there are any leaks, Change plugs, cap, rotor and wires. Clean maf and throtttle body with maf cleaner, Change air filter. Check brake pads and rotors. That's the basics.
