fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Thu Nov 17, 2005 6:04 pm
Personally I think it depends on what your goals are. If you are looking for anything under 400 rwhp, the -E engine should be just fine. There are lots of well built, solid KAEs putting out good power, there is no reason to swap at this level imo unless you have a real problem with the single cam.
If you are looking for more power than that, I would probably go with the DE. Not that the -E couldnt do it, it probably could-- just I personally havnt seen any huge power single cam KA-Ts out there.
