what should i do?sr20 or turbo my ka.
nismo_240sx95
Car: Nissan 240sx 1995
hey guys i got a 95 240sx.i was wonderin if i could get some advice.should i buy sr20det or just turbo my ka i got in my car now?
bwirth1999
To eac
nismo_240sx95 wrote:hey guys i got a 95 240sx.i was wonderin if i could get some advice.should i buy sr20det or just turbo my ka i got in my car now?
To each his own... I prefer the KA as it has greater displacement, and an iron block, same pistons as the SR .... I think the rods are even good for boost.
But, depending how much care has been taken care of the engine, really depends on how long the boosted KA will last you. You may never have a problem, or it may blow-up on your first run.. Everybody does the SR swap, but few have braved the KA... I say go KA!!
P.S. Don't boost it more than around 300-350 hp, unless you want instant piston missiles.. Untill you upgrade your internals..
carkook
When i think about it there is no replacement for displacement. Everyone is doing the sr swap, so i would go with ka-t.
You can turbo the ka with less money then doing a sr swap and with even the simplest setups its easy to make more power then a stock sr. I would take into consideration what condition your ka is in now, if it runs like crap now, turboing it isnt going make it run any better. If it has fairly low miles and has been taken care of you should be ok as long as you have a good tune. i would just check for leaks and do a compression test to get an idea.
AZ89two4Tsx
carkook wrote:When i think about it there is no replacement for displacement. Everyone is doing the sr swap, so i would go with ka-t.
well said.
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
KA-T.
'nuff said.
Ghostdrifter88
Car: 2017 Taco
use the search button...its flashing at the top
nismo_240sx95
yea thanks man.thats wat i think i was leaning more to.
letsrace98
SR20 all the way those motors are awesome
srcruz_13
have had both go with the KA-t...more power potential .... must have a tune though...
slipperypanda09
Car: 90 Nissan 240sx se, 91 Nissan 240sx le, 99 Subaru Impreza 2.5rs, 88 Toyota Supra Turbo
i like my n/a ka24de in my s13. im looking for a s14 to start my ka-t project right now. ka has proven better torque, reliability, and finacially more friendly than sr20. do your research and see what sounds better to you and your driving.
bwirth1999
SR engine are for the noobs of tuning.. no offense intended for those with SR engines... They are pretty much plug and play. Which is nice if you arent interested in actually working to get performance. The SR is nice because of it's higher redline, but that can be attained in the KA by getting lighter rotating gear, cranks, rods and pistons, but you usually sacrifice strength when doing so..
