AJ-SPEC wrote:you won't slow that badass down with stock brakes.
it would suck if you rear ended someone who cut you off at 130mph.
When did the car's mass increase?? Mass, in motion, is what a braking system stops. The car will not be traveling at any speed much greater than it already was capable of(if at all), so it's a bit false to suggest that factory brakes cannot slow a car that still weighs the same, and still travels at or near the same speeds. Increased power doesn't make a car harder to stop. Where did this idea originate??
It would suck under any circumstances if he rear-ended someone. In the instance you speak of, the likelyhood of such a crash depends solely on his chosing to travel at such high speeds in or near traffic(foolish). Larger brakes are no guarantee of avoiding such a collision...where a driver's anticipation/reaction are critical. If he, you, or anybody else that isn't driving a cop car is doing 130 near traffic, then you're wishing for death, and bigger brakes aren't what you need.
BUT I'M GOING TO NEED CLAMPING POWER.
This myth that increased power=less brake force is nonsense.
