These questions can help us help you figure it out:
- What color are your injectors plugs & harness connectors?
- Are they side feed or top feed?
- Can you give us a picture of them?
- Is there an adjustable fuel pressure regulator installed?
- What is the MAF part number?
Upgraded injectors, MAF and fuel pump can visibly look just like stock until you dig deeper to do some checking. If it idles & runs fine at WOT then the Mines ECU is likely running on a good base tune, and you probably have the correct matched MAF & injectors for the ECU.
Edit: BTW forget about the Q45 MAF - it will not provide the desired increased voltage range as an upgrade despite the bigger diameter. Basically worthless.
