What should I do about block??
sr20-thoj
Car: 89 nissan 240sx coupe
I have an s13 SR20DET black top. My motor is all apart as I speak. I have a problem with my block. The bolt holes on the block where the transmission connects to the block are stripped. Well the 2 bottom ones that are used for the engine stand that is. Im not sure what I should do. Should I just rethread it and get bigger bolts? or take it to a shop to repair? how much would it be? Any ideas?
Nismo_Freak
Car: 89 Nissan 240SX
You can use Timecerts, or just retap them.
sr20-thoj
Timecerts?? never heard of that before.. what is it? Ive actually never retapped anything before.. how would I do this?
karmakaze
Car: 98 240sx SE
sr20-thoj wrote:Timecerts?? never heard of that before.. what is it? Ive actually never retapped anything before.. how would I do this?
try to clean it and tap it out. When your are tapping it, use lube. Preferably aluminum tap fluid. but anything is better than nothing.
if that does not work, i recomend a helicoil.
time-serts might be a little over kill and in some area's they are hard to find. plus helicoils are cheaper.
timeserts:http://www.timesert.com/
either way, use loctite. that stuff is the ****. (blue if you plan to take it out again anytime soon, and red if you want it to be hardcore about it)
S13240
If I were you, take it to a machine shop to have it repaired. It's not that expensive.
tonis56
Car: 04 Titan Crewcab
karmakaze wrote:if that does not work, i recomend a helicoil.
Helicoil is definatley a life saver for stripped bolt holes. Used one on the timing belt tensioner bolt hole in my subaru and its held up nice for over a year now.
tony-
karmakaze
Car: 98 240sx SE
S13240 wrote:If I were you, take it to a machine shop to have it repaired. It's not that expensive.
where is the fun in that? besides anyone who is going to work on a car should have a set of easyouts and a helicoil kit. or at least know how to use them.
ILikeMy240sx
Car: SR Power
helicoil ftw
S13240
karmakaze wrote: where is the fun in that? besides anyone who is going to work on a car should have a set of easyouts and a helicoil kit. or at least know how to use them.
The fun is driving the car, not working on the car.
