float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Jul 19, 2013 4:59 am
First off, lets be clear, you're having a misfire, not a back fire. A back fire happens on carburetted/nitrous cars when the fuel in the intake track ignites and makes a loud noise and sometimes catches things on fire.
That being said, what can you tell us about the AFR's when it happens? There are multiple things that can cause a misfire. The situation you're in sounds like the engine is probably too lean and is failing to ignite the mixture at the load that it's at.
A video would help to diagnose the problem as well, but my guess is that this is less of a sensor issue, and more of a tuning issue. Have you tried making adjustments to the VPC?
