spitz7985 »
https://forums.nicoclub.com/spitz7985-u2738.html
Fri Jul 02, 2004 9:24 am
What temp. should a s13 KA-D thermostat open at? I thought mine was bad because my car showed all the symptoms, took it out, refilled and bled the coolant system, and it ran fine without one in so I assumed that the thermostat was the problem. Took it inside, put a meat thermometer in a pot of water, dropped in the thermo and turned on the burner. The thermo opened at around 180 degrees F. That seems normal to me? Maybe my cooling problem before was because there was air in the system?
