what sensors are these ?
s3xrapt0r
alright so today i dropped the drive shaft and started unplugging the electrical crap on the transmission the clips on 2 of the sensors were really high up and i count get a screw drive in to unclip them. so my friend cut the wires. there both on the passenger side of the transmission one has yellow wires one had black wires... i think ones a speed sensor but im not sure... a little help please i am going ot replace them so i didnt see the harm in cutting them lol
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
If they are up high, just under the shifter, then they are the back-up light switch and the neutral switch. THe front most one is the back up light swtich.
s3xrapt0r
there right out of my reach so id say they were sorta high up and there right next to each other. sucks both wires are the same color or i would splice them back together with some solder. but i cant tell wich is ground and wich is positive now lol. so there back up and neutral switches like he thaught then thanks :P this is the first time im actually doing something crazy like dropping a trans so im still a n00b haha
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Just use a muti-meter to find the ground (zero ohm resistance)
THis MIGHT helphttp://300zx-twinturbo.com/cgi...al=37
s3xrapt0r
thank you SOOO much that was the sensors i thaught !!
