rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Fri Feb 23, 2007 8:48 am
FCID. It allows the motor to idle up when you turn the a/c on. 90% of them come broken and it is not needed unless you want a/c...in which case you will have to have custom lines made (the lines on the compressor need the CA fittings braised onto the KA lines)
If you HAVE to have A/C, and you can promise me that you will in fact use it, I can send you one. For free.
