what's your oil pressure?
Fenvy
Car: 2005 350Z Base 6MT
i got the oil pressure gauge installed and it reads about
1000kpa (145psi) at idle4000kpa (580psi) at 3k rpm
is that about right?
DAEDALUS
Car: 1990 Infiniti Q45
LOL *Strongly* suspect your numbers are off by a factor of 10 somehow, in which case 14.5 and 58 psi are good numbers. That's with the oil warmed up and pressures stabilized?
Fenvy
whopps, guess it is 100kpa and 4kpa. haha! so 14.5 psi and 58 psi? damn these kpa reading, I wish defi made them in psi instead
and yes that's after the car warms up, so is that normal or a bit low?
black s13
mines right around 24 at idle, and about 53 at 3000.
w1ngzer0
Car: Pfft. i don't own a box
i don't know, i don't have any gauges hooked up X_X
DAEDALUS
Per the '94 manual numbers should be >11 psi at idle and 60-70 psi at 3000 rpm.
Fenvy
I forgot to mention that it's for a s13 sr20det...
