You didn't read that here! Avoid K&N and go with OEM fromjoe maniqz wrote:.i read here somewhere that k&n filter gave his car a boost on it's mpg....
Go with Redline. BG44k is a waste of money since they changed the formula. I think they sell it at pepboys.maxnix wrote:You didn't read that here! Avoid K&N and go with OEM from
http://www.infinitipartsusa.com
http://www.bgfindashop for your BG44K or use Redline SL1
I go through full tanks of gas with 100% city driving averaging 35-45 mph 90% of the time and get 13.5 mpg in the 90Q and 14.5 mpg in the 94Q. Both are well tuned and there isn't much I can do to squeeze out better fuel economy. Where you're living in the San Fernando Valley there's a lot more (a whole lot more) stop and go traffic than in podunk Sacramento. Your only getting 0 mpg when you sit at a red light or are creeping forward at a busy intersection.joe maniqz wrote:I have a 1999 Q45 and it's 12 MPG on city driving!!! Fuel economy .gov listed it at 16 MPG. What do I need to do to get 16 MPG? Clean or replace injectors?
You need to pull up a chair and do lots of reading.jasonhirt23 wrote:Why not use K&n filter? I just bought a 1993 q45....does it not benefit the car or not good? Also, what about iridium spark plugs? Are they worth putting in for gas mileage and etc.?
OEM intake draws cool, dense air from a good location. A cone filter sitting in the engine bay will only be a downgrade. A K&N style filter might feel more powerful after startup but, once you're up to normal operating temp, the engine bay is soaked in heat. Stock intake takes air from outside the engine bay, avoiding that problem. At speed, it has a nice supply of fresh, cool air. A K&N cone filter doesn't.jasonhirt23 wrote:Why not use K&n filter? I just bought a 1993 q45....does it not benefit the car or not good? Also, what about iridium spark plugs? Are they worth putting in for gas mileage and etc.?
Odd. I wonder if something else is wrong? Wes is always touting the fuel-economy benefits of high-stall TC over the 4.08...I'd expect you to be doing much better than 10.Trumpkin wrote:My dragon tc and shift kit killed mine, about 10!
And in real world driving, the true difference is about 1.0 -1.5 mpg.Q45tech wrote:Only does the Q41 with smaller engine and weight avoid the gas guzzler tax increment.
You will. The last thinkg an engine wants in front of a hot wire MAF is an oiled filter element.MAX_POWERS wrote:My Q came with a K&N drop in filter when I bought it and have not had any problems. I read here that the oil on the filter is suppose to to get the MAF dirty. I have not had that problem with in the 3 years I owned my Q. I cleaned and re-oiled the filter last summer.
