What's your idle AFR ?
gyfer
Just bought a Wideband O2.Trying to learn about tuning.Mine says 12.3 at idle... I would say that's wong.
What's your AFR during idle ??
crzycav86
Car: 93 Nissan 240SX KAT
what are you using for tuning? safc?
KATwo40
Car: 1993 240sx KA-T
Mine is 14.7-ish @ idle.
gyfer
I use Emanage.
How about everyone else ? Give me your AFR @ idle !! Don't be shy
SeanC
Car: 1993 240sx SE
high 14's low 15's is perfect for idle and cruising. then at WOT look for 11's with a turbo and 12.5-13.2 for n/a.
MarkEmark
Car: fully-built '95 240sx KA-T
gyfer wrote:Just bought a Wideband O2.Trying to learn about tuning.Mine says 12.3 at idle... I would say that's wong.
Yah, that's definitely too rich. Even with a JWT ECU, I'm running between 14.7:1-15.2:1 at idle.
Cruising at full vacuum, it's 20:1
Florida240sx
My idle is like 11-12 as well. Your idle should be 14.7 Anything between 14-14.7 will be fine. My first setup i was able to tune it and I had it at 14.5 Now with my 555cc's I can't get it above 13.
Chezedik
Car: 1991 Nissan 240sx
Idle can be as high at 36:1, there is no need for full enrichment without boost conditions. I would say 20-25:1 is more than safe if not too rich.
1WheelWonder
I sit at around 14.5-15.5 at idle and cruise with 550cc Deatchwerk injectors and SafcII, soon to be Enthalpy tuned.
DammitBobby
Car: S13 91 KA24DET
Car wont idle at 19 to 1. That is what JWT 72lbs reads. I had to add 30% fuel to get the car to idle around 14.7. You don`t want to have stall issues after boosting. It will fry your turbo bearings. Ask me how I know.
gyfer
That's for the input guys.
How cruising at constant speed, say 70mph ??
Chezedik
That just comes from my recent experience with helping to tune a K-pro, it idles fine while logging a constant 38:1. But it could just be having trouble reading, who knows.
Jookmasta
well initial startup presents 18:1 or 17:1 but then when the engine is warmed up, 15:1 or so...........this is with the enthalpy tune....
BillKlineVT
lol at 38:1 what mileage do u get, 300 mpg? sounds like whatever wideband ur using is broken if you're seriously getting 38:1... ur car should start to buck at anything leaner than 17-18:1, if not before that. I idle between 15 and 16 most of the time
180sx
well yah 14-15 at idle and cruise. 12 in boost otherweise ur idle is a waist of gas ...1thing to watch is motor has to be fully warmed up cuz u have self learn function ecu ussses as well as warm up enhacements.
and there isn't a replacement for displacement by the way.....3.5l turbo will smoke a 2.5l turbo motor just like ka's kill sr and ca'a if you look at it that way
gyfer
Thanks for the input and reading my signature
I repeat, if you think there's no replacement for displacemnt, you don't know anything about physics and chemistry.
Peace
