What's your current mod project? Then what's the next one?
Eikon
Car: 71 240z, 93 Supra TT
Since we all like to work on our 'verts, I think it would be interesting to see what everyone is working on right now!
So, everyone post what your current modification, refurbishment, or install is. How long have you been working on it. Are you having any trouble with it? What will it do for your car. When you are done... what's the next thing on the table?
I'll go first.
Current Project:Installing KYB AGX shocks and Eibach Sportline springs. Should be about 2" drop and really help the appearance and performance of the vehicle. I think my stock suspension is a bit on the bad side anyhow.. so this should really help a ton. I am having a hard time with the install.. The bolts on the shock to hub connection are really really hard to get off... many sprays of pb blaster and nights to soak in finally helped me get the front left side off.. Yikes!
Next Project:I've got a faulty thermostat that sticks. The pressure buildup also ruptured a coolant hose.. making the car basically undrivable. (not a big deal since it's in the garage for the winter). But, replacing the t-stat (or getting rid of it completely) and getting a new coolant hose will be the next project. The only problem is that it will be a challange to reach w/out removing the intake manifold.. that's a lot of work!
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
current project: pulling parts off/out.
next project: i'm thinking about pulling the old ka out of the vert. if i do, i'm going to tear it down in my basement and rebuild it for boost. it'll probably take me a year to have it ready to fire up - mostly because of finances and my other non-vert projects (like my rally-spec DSM). i shouldn't have any problems because i'm good like that.
BOOMSHAKALAKA
Current project: I'm planning on what mods I want to do. I am also doing research on things I don't know about and looking at prices so I know what I can work with.
Next project: Getting a job, saving up my money, and actually doing some mods. Some of the first mods i'd like to do are getting a new exhaust, rims, coilovers, brakes, and tint. I wanted to turbo the KA but I would love to be the first vert owner (I think?) to put in a CA18DET in so that is kinda like my main goal.
THREADJACK... Hey Seth I remember a while back you were asking for feedback on a new 240sxconvertible.com homepage design. Any updates? ...THREADJACK
biggie
This weekend will try to fix interior lights not working and cruise not working. Cruise hasn't worked since it was bought, narrowed it down to 2 items. Interior lights went out after headunit install, shorted either dimmer switch or TCU.
Next: Want S14 front seats. Getting Eibach Prokits, will save for AGXs before I install.Sidenote: when I had Sportlines on my old coupe they were too low and too soft, hope they've improved since then.
Main project is my coupe (front crossmember alignment and turbo install to happen within a couple months), so the vert is a back burner thing.
I have a monster list - all "little" things, but need to be done:
Wetsand / polish bodykit
Pull off VC / IC piping / heatshield / shroud / other SS bits (for polishing)
Fab up heatshield for MC
Install braided SS clutch line (replace old bent hardline)
Install dual gauge pod (steering column mount)
Buy / install boost controller (anyone got one?)
Install new Endura-Tech coilovers
Polish wheel lips
Refinish brake calipers (to red from gold)
Install SPL big-brake kit
Reroute PS line
Remove top mechanism, glass, and top motor (this summer)
Remove AC compressor / condenser and lines
Install torque damper
Swap out 4.36 VLSD for a better unit
....there's plenty more - car projects are NEVER done!
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
Current necessary but not fun projects:
-Tune up-Passing emissions-A day at the DMV getting plates and title
Current fun projects:-New trunk struts (I may have found a cheap source for these - will let you all know once I confirm it)-S14 Silvia emblems on front and back-Q45 front brake upgrade-Revamp the interior (red leather steering wheel, red vinyl inserts on doors, dye carpet black, S14 seats)
Next projects:-New suspension-Motegi Track Touge 17" rims and new tires (unless I come across a cheaper used wheel and tire combo locally)
biggie
ishkabibble wrote:Current necessary but not fun projects:-New trunk struts (I may have found a cheap source for these - will let you all know once I confirm it)
FYI they were $22/each or so at Pepboys last month when I got mine. Hopefully they are cheaper somewhere else.
ishkabibble
1997 Infiniti I30t
biggie wrote:FYI they were $22/each or so at Pepboys last month when I got mine. Hopefully they are cheaper somewhere else.
I think I found em for $12 each (not including shipping)
Eikon
topless94 wrote:THREADJACK... Hey Seth I remember a while back you were asking for feedback on a new 240sxconvertible.com homepage design. Any updates? ...THREADJACK
Continued Threadjack.. With everyone help, I've got a layout I like, and the ideas that I want to incorporate... I just need to find the time to put things together. If you want an idea of the layout... I really dig the Versa portal page... http://www.nissanversa.org/I will replace "purchasing FAQ's" with Online Gallery. Plus a couple other tweaks.. End Threadjack...
Glyph
Car: 1993 Nissan 240SX Converible
Eikon, I just replaced my thermostat last month. Unfortunately, the back pressure caused by my faulty one actually put a 2 inch crack in the plastic part of my radiator. You'll be happy to know replacing it only took me about 15 minutes and the only thing that needed be removed as I recall was the plastic raduiator fan cover. Even that was removed just to make it a bit easier. From there it was fairly easily reachable with an extension. The bottom bolt you can't see was the only real pain. Good luck.
As far as mods go. Right now I'm trying to save a little money so I can put new wheels and lowering shocks and springs on it. I'm tired of looking ready to enter a monster truck rally.
Eikon
glyph, Unfortunately my thermostat will be much more challanging to reach on my RB20 than the KA engines are. It shouldn't be a problem normally, but I have a custom intake manifold that covers a lot more surface area that the old one and thus it makes it nearly impossible to reach the t-stat. It's gonna be tough!
But.. If I have to pull the manifold off.. so be it.
wirelessalpha
Car: 93 SR Vert, 96 318ti, 06 Altima
Mods (or should I say...to do list):
1. Cage. Just been lazy to get this done - but believe me, it will be done Q1.
2. My seats installed: Would you believe I bought 2 sparco race seats and they have been sitting for months?
3. Raise the boost! and ECU tune.
Glyph
Eikon, My bad. I forgot you were sporting an RB20. Oh well, Sucks to be you. JK of course. Good luck to you. Sounds like a royal pain the way you describe it.
My to do list is as follows...
New wheelslowering springs or coilovers if I find some cheap enoughnew catback exhaustbody kitpaint job
By then I'll most likely be approaching retirement so I'll probably just opt for a somber medium gray or something equally soothing.
BOOMSHAKALAKA
Glyph wrote: My to do list is as follows...
Paint job? The paint on your vert looks great...
But if you want to paint it gray (I like gunmetal) go for it. It'll be unique. But if I may throw an idea out there...have you thought of a champagne color? If you get that with a set of gold colored rims, it will look very classy...something that will go well with the approaching retirement.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Where to start >.>
Current Projects:Door conversion. I have my coupe doors stripped out and getting them prepped for paint. Shouldn't be too much longer hopefully.
Rear Z brakes. Just need to track down a N/A Z32 to steal the e brake assy out of it.
Upcoming projects:Silvia front end (guess that would be a sidegrade, not an upgrade <.<) and repaint of the car (paint being one of the few things i won't be doing to my car)
pondering doing a 5 lug upgrade (parts available to me for a good price has me considering it) and wheels.
New turbo and supporting mods (a ways down the way though)
Gonna rework the entire suspension as well. KTS coilovers and new rear sway bar. Adjustable alignement bits to follow.
New top is in the words.
Oh, but i need to win the lottery first
nissanconvert
Car: 94 300zx Convertible 5 speed
Winter projects:new battery, likely will be optima redtop (i think the old battery is bad)trunk struts ( i have scars on my head that need to heal)new window buttons (nubs are hard to push)another windshield (an unfriendly tree recently made a mess of my first new one)KYB AGX struts (summit racing has em cheap and i don't have to pay shipping)Tanabe GF210's (the wiggle of my blown stock suspension is driving me nuts)Hopefully I'll have money left for adjustible rear upper arms and front mounts to fix the camber.
Alpha, I thought you had a set of kick *** blue s15 seats, or I could be going insane?
Ace~
Car: 1994 240sx Convertible
Current Projects-Replace Cloth top(350$ install 350$ top)Fix front end damage from suicidal deer(600$ maybe less if I forgo painting it)Manual Swap(free transmission, 100 dollars for all extra items, probably free install)
Also I'm creating a plan to spruce up my interior. I plan on replacing the water damaged carpet and taking it all the way to the back where the back seat used to be, then fabricate a light metal sheild for the now exposed convertible assembly with a water proof lining....
Long Term Project-KA-T!
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Current projects-Tracking down a havac motor to finish up my digital climate control project.-I need to get my lazy butt out to the junkyard and pull the big hose for my leaky power steering system.-Front suspension is done. Currently researching and deciding what parts to replace on the rear suspension.-Cleaning the filthy rear undercarriage.Future projects-Got engine money. Saving for install/parts money.
masterteque
Car: 1993 s13 convertible 1993 s13 coupe
My upcoming plans:
Order my Full Race T3 Top Mount Pro Street ManifoldOrder my Gt3076r Garrett TurboOrder my Apexi Power Fc D Jetro
Hopefully aquire everything this winter and get tuned early in the year as soon as the salt is off the roads.....
slownslurious
current project: pull ca18det, swap to v8, install roll bar, Z32 rear spindle and shock swap, front big brake kit install, weld core support, install water to air intercooler for the supercharger, rebuild the v8, install the triple disc clutch and the 5 speed, install the nismo 2 way clutch lsd, make a custom driveshaft, install the sparco seat, make fiberglass copies of the door panels and the dashboard, make custom gauge cluster, strip the insulation off the floorboards, finish molding the body kit and get the car primered. Oh, and make a custom speedster cover and a bikini top to go from the header to the rollbar after I pull the stock top off.
next project: kill all the white man.
positron1
[QUOTE=
next project: kill all the white man.[/QUOTE] What's the deal with that?
slownslurious
not a fan of NOFX?
wirelessalpha
you going insane.
I have a set of kick asss sparco evo 2's...never installed yet. Been sitting there for months. I also have a set of nagisa rails whihc won't work - even with crazy fabrication ideas I've thought of.
So - I ordered a set of sparco side rails...gonna use those...and sell these nagisas. anyone? [email protected]
slownslurious
I'm actually in the process of doing a sparco evo install into my friends hatch... the easiest and most sturdy way to mount them AND keep sliders is to dissect the stock seats, save the sliders, and bend some heavy gauge sheet metal on a brake to bolt up to the stock sliders and the seats. each side would be one piece of metal. its very strong. thats when I'm doing on ben's. I'll try to take some pics. Ive got a sparco roadster myself.
TIMELSS_vert
current - pay off some **** and gear up for the holidays...
next - conversion, kit and wheels, if I am feeling ambitious there might be some one off aero and glass work...
tigwebu
Car: 1993 Nissan 240SX Convertible
Current Project: to get the chiro to fix my d@mn back so I can install my parts before the spring. Check it out. But Currently I really trying to finish the 5spd conversion. zerothread/196421
Future Project - Don't know it never ends!!!! But I want to install a rollbar, go crazy on the suspension, like power brace, sway bars etc!! Mad Handling Skill
Modified by tigwebu at 1:58 PM 11/20/2006
onosqv
Car: '92 240sx Vert
Currently getting my rollbar done, whoopieeee, YAY for awesome local fabricators!
slownslurious
brokeAs240sx wrote:Currently getting my rollbar done, whoopieeee, YAY for awesome local fabricators!
what kind of bar are you getting, how much will it cost, etc?I want one like autopower race rollbar but can't find anyone local capable of handling it. well, found one place but their prices are like $$$$.
onosqv
Car: '92 240sx Vert
slownslurious wrote:what kind of bar are you getting, how much will it cost, etc?I want one like autopower race rollbar but can't find anyone local capable of handling it. well, found one place but their prices are like $$$$.
Well, it's gonna be basic 4 point rollbar w/ harness & crossbrace. Basically SCCA legal style. it's at least $500+ (details haven't been finalized yet & I may have some other small tidbits added on it, but his starting price is 500 for basic basic rollbar so you have an idea). Should still work w/ my interior panels & top. Seats probably won't fit back there no more - not a big deal once I get that rusty **** painted, haha.
The guy building my cage is getting started in this, but welds lots of different stuff, competes in formula d and does his own cage - so like his lil side job, does very meticulous work and is totally working w/ me on the design. Found him through a friend's referral.
I'll post details on it when I get it back, hopefully in time for autox this Friday, woo woo!
94_240sx
Car: 94_240SX
I've waited until I receive these.
Current Project:1. Complete z32 brake swap including rear & e-brake2. Saving money for the next project
Next Project:I have too many to list, but I really want to do manual swap done. Collecting the parts and getting ready for the swap would be my next project.
BTW, I do all the all by myself after the work in my garage, so the progress is very very slow. I'm okay with it though. I'm a patient person, and I enjoy every moment...
