deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Sep 11, 2005 9:30 am
Looks like most (maybe all) of your intake side rocker retainers are bent/distorted. I have no idea how someone could have been brainless enough to do that, but you will need to replace them.
The retainers im speaking of are the sheet metal parts that align the rockers on top of the rocker shafts. If you happen to have another ka24e around swap them over. If you dont, your going to have to look around because those cant be fixed (possibly could, but not worth it).
Be sure to follow the proper procedure when removing/installing the rocker shaft bolts. You do not want to bend the shafts.
