nismo1003 »
https://forums.nicoclub.com/nismo1003-u8632.html
Wed Dec 03, 2003 7:04 pm
since last time I was driving my car with a screw up DENSO Iridium spark plug, now my car can't stay on( it keep dying). fuel get in to the oil pan, melt down the silicon and my oil pan is leaking oil. my spark plug screw up, bad injector o-rings, nothing works. yesterday, I redo the oil pan reseal it clean it. change oil filters refill some new motor oil , change spark plug ( NGK 1 step colder copper plug), new spark plugs wire. compression test ,all four is good. change the o-ring from the injector ( all 4 brand new o-ring). change some parts for the T3 used turbo ( off from 300zx turbo) and then I tried to start my car again, it didn't want to start , and then I crank couple more times, it would start and it can't keep in idle and die. but if I keep it at 2000rpm, it will stay on. I shut it off and check it again, cylinder #4 leaking fuel from the exhaust manifold , the spark plug #4 all wet ( I believe it was too wet ) . what's the problem, what make it not working? anyone can give me some advise?
I was thinking my distribator cap and rotor went bad? i never change it.? what do u think
fuel pressure at 50 psi when start and keep dropping. I upplug the injector and keep the fuel pump and look in to the spark plug hole and see if there any leaking fuel from the injector. they are fine.
I changed some part for the T3 Turbo,there aren't that much shaft play anymore after I changed it but it is harder to turn, can anyone tell me what I did wrong? I align it ( OEM spec), while I put everything back , there is a lock clip next to the turbine ( i blieve it's to lock in place the turbine from keeping off the place). that clip I think it expended , so that make the turbine harder to move, I hope when things break in..it would move freely. I was also thinking is it because the turbine wasn't turning freely so make my car die? but hwo can I explain why the fuel is leaking still
even when I had the screw up DENSO spark plug, it last me two days ( my car was drivable) , but now I change out hese NGK spark plug..I think it's worse. ANY comment, Advise , suggestion would be good
