What's wrong with my 240?
BIGTIMER_240
Car: 1989 240SX ka24de
my friend just bought a 240 and somthing is wrong with it takes a long time to get hot but when he accelerates the engine shakes and it dosent get the speed right we check all the vacume lines and change the gas filter,gas pump, injectors and it still rattle when accelerating also the tachometer goes crazy and thats when it rattles and shuts off it sounds like an injector was not pluged in right but we have check everything so we really need serious help
Eikon
Car: 71 240z, 93 Supra TT
I'd say the first thing you need to fix is your ability to communicate on an internet forum.
Try again with proper sentence structure and punctuation. Then we'll be able to understand what you are asking and possibly be able to assist you.
Thanks
E7-S14
Car: ess 14 foo!
Periods FTL....
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
check for spark on all cylinders. check the plugs. how does it idle??
sweets13
was it like this when you friend bought it? If so wtf did he buy it? Like the guy above me said check for spark, check plugs.
BIGTIMER_240
we have check the spark and all off them work they throw good spark
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
What motor? SR- Coilpack harness, KA-Distributor. Start there.
BIGTIMER_240
ka distributor
tlkq
...no. He was saying if it's a ka then check the distributor...
BIGTIMER_240
the car still shakes and shuts off
xckid
Car: 2004 Chevy Blazer ZR2
i had a similar problem like your friends,only mine was due to being in some rather deep water. got my dist. cap and rotor wet. and my mafs. Car ran like crap could not hold idle misfired like crazy when i stepped on it. Try replacing the cap and rotor it will only cost you like 25 bucks at the most for in total no real big loss if it wasnt the problem just means you have better spark.
TougeMS13
Car: '91 coupe
Throwing a Cel or any codes?
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
did you pop the valve cover off?? the last time i checked my valve lash i forgot to tighten a ground on the back driver side and it ran like piss till i noticed that.Check your grounds.Have you also checked timing and or compression.
BIGTIMER_240
what is the cap and the rotor
driftneil
Car: A pile of cars.
BIGTIMER_240 wrote:what is the cap and the rotor
Abort misson...walk away from the car now!
gripstr
Car: Street Legal s13
driftneil wrote:Abort misson...walk away from the car now!
No seriously you for real man?
slyedog240sx
i think this needs to be redirected to a i am a newbie i have a question thread
BIGTIMER_240
i know the cap is the distributor cap , but wich is the rotor is it the black thing inside the cap just help me out pls
deuceforty
Car: 1995 240sx
BIGTIMER_240 wrote:i know the cap is the distributor cap , but wich is the rotor is it the black thing inside the cap just help me out pls
how could you have possibly checked them if you don't know what they are?
edgartheace
Car: 1993 240sx, 1992 300zx RIP, 1993 300zx 2+2, 1993 Infinti J30t
I'm not to far from you guy's. If you still can't get it work let me know. I could stop by tomorrow afternoon and take a look at it for you.
BIGTIMER_240
CAN YOU COME NEXT SATURDAY
driftneil
BIGTIMER_240 wrote:CAN YOU COME NEXT SATURDAY
Maybe he would, if you would stop YELLING.......
frosti108
Car: rb s13 coupe
how does one yell on the internet? looks like his caps lock is just on...
and this isnt school, people... calm down. if you dont want to help him just stay out of the thread. its a pretty simple concept.
driftneil
[QUOTE=frosti108]how does one yell on the internet? looks like his caps lock is just on...
and this isnt school, people... calm down. if you dont want to help him just stay out of the thread. its a pretty simple concept. [/QUOTIt was a joke, Cry about it Ive been reading this thread for him to elaborate a little. You ***** so much about not helping, and you post for me and not he o.p. Take your own advice. Not trying to fight on here, LIGHTEN UP(<<<<<looks like I yelled)
driftneil
BIGTIMER_240 wrote:the car still shakes and shuts off
Did you check the MAF? Disconnect...if it runs the same, its bad.
mchkc240
Car: 91,92 Nissan S13 - SOLD
98 BMW E36 - Running
I will say it might be the timing chain. Hopefully that's not the problem... Because timing chain is a b*tch to work on
tigerpawkc
Car: 1995 Nissan 240SX
Yes, the thing inside of the distributor cap is the rotor, it rotates and the metal pieces on the ends of it hit the metal inside the cap and start the chain of events. Have you checked it yet? I'd say just go ahead and replace it, even if it's not the problem this time it eliminates the possibility for ya and you won't have to worry about it anymore. Also, just give us an update- have you checked the spark plugs/ made sure the wires are connecting to the plugs and the cap?
BIGTIMER_240
everything is connected i havent tried the maf ..... ok this is the problem when the car turns on it stays on a little while. when you put it on drive the car shakes and if you dont give it gas it turns off. like if im driving it and i stop on a stop sign the car would shake and start to turn of so i have to put it on neutral and rev it up a while so it would go on, maybe to the next stop with out shuting off
edgartheace
I can be there in the afternoon since I have to pick up my brother at the TJ airport in the morning.
BIGTIMER_240
its cool just give me a call i send you an email with my number
