masticatingcow »
https://forums.nicoclub.com/masticatingcow-u11112.html
Wed Apr 27, 2005 8:06 am
I have the same problem, but in the rear. There just a little (maybe 1 degree) more negative camber on the passenger's side than on the driver's side, which makes it look a little more sunken in. If it handles, don't worry about it, but if it feels squirrelly, then have it checked out.
Slamming the car will produce negative camber. Check the space between the top of the tire and the fender on both sides... are they lowered equally? Even a 1/4 inch could cause inconsistant camber, AFIK.
Anyway, if it is your LCA, it'd be a pretty good time to overhaul your whole suspension!
Modified by masticatingcow at 3:00 PM 4/27/2005
