What's up with these fuses? (pic)
rgk
Car: 02 Pathfinder LE 3.5 auto 4x4
2002 Pathfinder LE 3.5, fuses 10 & 15. Why do these fuses have wires sticking out of them? If I am reading the FSM correctly, #15 should be empty. The wires both lead to two more fuses, then from there the wires trail upwards, as if going toward the driver's side speaker in the pillar. Is this a factory job, or a custom job performed by the PO(S)?
atraudes
Car: 2001.5 Infiniti QX4 4WD
Looks like an improvised fuse tap. It's probably providing power to some added overhead accessory like a GPS unit, dimming mirror, etc. If you don't have anything obviously aftermarket, you'll probably find the wires lead to some tucked away wire. The side pillars aren't too hard to snap off if you want to track it down. If I recall, you should be able to insert a screwdriver and the top and persuade it out.
rgk
Thanks. Say, what's the new avatar? Abstract New Mexican food art?
atraudes
It's a painting by Jeff Jordan that's the cover of Mars Volta's Octahedron album. I decided to go for something a little more...out there :biggrin: I've been meaning to ask, what's yours? As best I could tell, it's part of some sort of physics flashcard set.
rgk
It's a diagram outlining the difference in torque depending on where you grasp your wrench :cool:
I grew up more dandy than handy, so I have a healthy appreciation for art. I think I'll always be in this weird in-between state.
atraudes
lol Ditto
