The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Tue Jan 21, 2014 3:46 am
I believe there are heat-reflective nearly clear films that can be purchased. I was thinking you may have had one of them. I don't know if you could just add another layer to that or not. Did you tint yourself or have it tinted? If someone else tinted, you may have never noticed the first film, and they may or may not have removed it before adding the second. Did it get worse with the tint? Is your car a CARB compliant car (California Air Resource Board)? I think it would have a sticker under the hood if it is. I know that California requires heat reflective windshields that can interfere with GPS and stuff, so maybe if you are pulling into your garage, the windshield is interfering and then the garage door being closed is a little more interference. OTOH, when already in the garage, signal doesn't need to go through the windshield, and when backing out and closing the door, the door isn't already closed to be a little more intereference. Seems like a long shot, but if you're pulling in, try hitting the button before you're facing the garage or try backing in.
