That solenoid is designed to send pressurized oil to the intake camshaft sprocket to actuate it. Pressure can be anywhere from 10-80psi.my12by60 wrote:The same part on my recently purchased 2000 was covered with even more oil than as is shown in your picture. I cleaned it up real good and am keeping an eye on it in an attempt to figure out where the oil is coming from. Do you think the VCT itself is leaking or does oil from a valve cover gasket leak somehow make its way up the solenoid? That defies gravity, but maybe some sort of electrical reaction draws the oil up the solenoid.
full disclosure: i've not messed with those solenoids (but changed both sides vcg twice) as mine don't leak. but, if there were leakage at the solenoid to head interface i'd fully expect it to resolve with a fresh o-ring or crush washer, or worst case thread sealant (the kind with an aerobic cure).my12by60 wrote:I was searching for that part myself just to check the price and availability in case I confirmed that mine was a leak source. I was unable to locate the part on-line. Let us know if you come up with anything.
When you say "bubbles out", do mean you can actually watch the oil come out of the part with the engine idling? Can you tell what section of the part the oil is coming from? From reading around, I believe the part threads into the engine block and there is an o-ring at the top of the threads. If you are leaking from the threaded socket into the engine block, then maybe you can get sealed up with a new o-ring. Or are you leaking from higher up on the VTC?
Bubbles right out the top. Probably has something to do with the P1320 and misfire code...my12by60 wrote:When you say "bubbles out", do mean you can actually watch the oil come out of the part with the engine idling? Can you tell what section of the part the oil is coming from?
those connectors are my least favorite nissan versions. there is a 3 sided "rectangle" spring clip near the bottom that needs to be release.my12by60 wrote:After I cleaned up my solenoid, I was studying it in an attempt to figure out how to disconnect the wire harness so that I could unthread the solenoid and examine the o-ring and threads for signs of oil all the way up the threads. I could not figure out how the harness disconnected so I gave up and decided to just watch the solenoid for signs of leakage vs. potentially breaking something that might not be the source of problem to begin with.
3Q - When you mention a thread sealant with an aerobic cure, what brand of product would you recommend if I end up needing to go that route?
my12by60 wrote:
Dodgey,
Have you installed your replacement part yet? Any issues getting the old out and the new in? How about that grey harness to the left (in your pic) of the solenoid? That looks like it is a pinch and pull similar to the fog light harness that I disconnected when installing a replacement fog light. Did you disconnect that one to create working room?
So you're saying this could be the reason for P1320?Dodgeyaussie wrote:Bubbles right out the top. Probably has something to do with the P1320 and misfire code...my12by60 wrote:When you say "bubbles out", do mean you can actually watch the oil come out of the part with the engine idling? Can you tell what section of the part the oil is coming from?
I really didn't want to disturb the wiring harness anymore than i had to, so i removed the bolts necessary to get some movement in the bracket in front of it, then a 27mm socket did the trick to remove the old and install the new.my12by60 wrote:
Dodgey,
