Here's the story: I had a knocking noise in my red-top sr20 that sounded like it was coming from the lower engine. I assumed it was a spun bearing. I started a tear-down to confirm this, and when I pulled the oil pan I found this in there. It's aluminum, has somewhat of a taper, it's pretty worn but I assume (maybe incorrectly) that it was a full circle originally. I don't know if this was the source of the noise or not and I'm still in the process of checking the bearings, but there wasn't any metal or shavings in the oil (except this). Anyone have any idea?
