What's the widest wheel to fit on S14 240sx?
dmora
i'm planning on possibly getting some Fikse's for a S14. Fikse's are custom forged wheels and I would like to try and get maybe some 10.5-11" wheels in the back and maybe 9-9.5" wheels in the front. Not sure if i wanna go with 17"s or 18"s. Im leaning to 18"s though.My idea is to try and get 285s in the rear and hopefully ~265s in the front.
I really dont like the puny sizes all the JDM wheels come in, and i would like something beefier for the project i have in mind.
I'm trying to pick between these wheels...
Fikse Profil 5S
Fikse Profil 5
or the original Fikse FM/5
Exar-Kun
Car: 2005 350Z
1. why?2. why?3. why?
I dont understand why you would want such a wide wheel on the car, much less the reasons for it. YOu dont need that large of a contact patch, and essentially you just make the contact patch wider instead of longer. YOu can fit a 10" wheel in the rear, but you have to get flares and a very low offset wheel, same thing goes for the front(up to a 8.5" I think..)-chet
SmithSR
Car: 240sx
Fikse builds some great wheels. I've had the pleasure of working with several customers who utilize Fikse wheels for amateur racing applications. Have you called Fikse?? As you said, they do make custom forged applications, so if you have about $1000 per wheel, they can build it. Definitely look them up!! Fikse wheels are of the highest build quality.
SmithSR
Car: 240sx
chet is right, too. you really don't need such wide wheels. but if you're gonna get aftermarket wheels, and money is not an issue, Fikse is second to none IMO.
dmora
Exar-Kun wrote:1. why?2. why?3. why?
1. i plan on making some big power.2. traction is good.3. wider is better.
I guess i will have to do my own research on what i can actually cram in there? Does anyone know who currently has the widest wheels/tire combo on their car?
dmora
SmithSR wrote:Fikse builds some great wheels. I've had the pleasure of working with several customers who utilize Fikse wheels for amateur racing applications. Have you called Fikse?? As you said, they do make custom forged applications, so if you have about $1000 per wheel, they can build it. Definitely look them up!! Fikse wheels are of the highest build quality.
I have a contact with Fikse and can get them for significantly less. :)
Exar-Kun
Car: 2005 350Z
traction is good, how much power, over 400hp, becuase chris may used a 255-40-17 and it held up fine under 438rwhp, more than most people even contemplate making in our cars.
and Like I said, traction is not just a fucntion of how wide a tire is, a 245-45-17 may look like this(contact patch) --( )( ) --(longer than it is wide)where a 285-30-18 looks like: -----( ) -----(wider than it is longer)
hopefully that helps you a bit...traction, if its an issue fater you get to a nice sized 17 or 18"(255-40-17or a 265-35-18 for example) should be taken care of by choice of tire, not just width, you really not need any wider tire.-chet
dmora
Exar-Kun wrote:traction is good, how much power, over 400hp, becuase chris may used a 255-40-17 and it held up fine under 438rwhp, more than most people even contemplate making in our cars.
i know the function of tires and propper sizing. Im not a ricer that wants pizza cutters for wheels and tires. I plan on running 295~275/35 and 275~265/35 BFG TA/KDs or S02/S03. I used approximately these sizes on my supra for daily use and track events. I hoping to run something a little better than an SR20. ;)
All i want to know is the depth of the wheel well and would it reasonably fit a wide *** wheel/tire combo with out rubbing or rolling the fenders. I didnt think i would get into a debate about wheel and tire fitment dynamics. :(
SmithSR
Car: 240sx
You should be able to measure the depth of the wheel well with a tape measure, yes?
Also, the biggest thing that'll fit isn't necessarily going to be what will work best, as I'm sure you know. The only way to find out what will work on your car with your suspension/brake setup is to find a shop that has what you want in stock, and is willing to test fit on your car. Shops like this are a very good thing and very very hard to find.
Fitment dynamics should be discussed more often so the typical "what'll fit" question is avoided. IMO, asking this question only results in people's opinions, which may or may not have validity.
bigE
Car: Anything dealing in cars.
Find Nils on the site, He's running some wide Volks on his S14, I think they might be 10's in the rear, contact him and see what offset he has, and the wheel and tire size. He might be able to help you with the fitment issues.
Eric
Dr. Ifto
Do any of you know whats the widest to put on a 90 240sx hatch??
SmithSR
Car: 240sx
did you run a search or check the FAQ section yet? tons of info to be had.
C-Kwik
I know for sure 10" wide wheels will fit in the rear of the S14. Possible even a little wider. I test fit one a few years back, and it lookied like there was some room to spare on the inside. But keep in mind, the widest I've seen fit in the front of an S14 was a 245 tire on a 9" wide wheel(slightly sticking out). At over 10" wide, you are looking a 275+ and you may star getting into some serious understeer with that much stagger.
plastik240se
Car: 96 240sx se
C-Kwik wrote:I know for sure 10" wide wheels will fit in the rear of the S14. Possible even a little wider. I test fit one a few years back, and it lookied like there was some room to spare on the inside. But keep in mind, the widest I've seen fit in the front of an S14 was a 245 tire on a 9" wide wheel(slightly sticking out). At over 10" wide, you are looking a 275+ and you may star getting into some serious understeer with that much stagger.
Did you try out the 9" (you like?) or was it just a throw on while up on the rack or somthing:confused: :jet: love these smilys
plastik240se
Car: 96 240sx se
Im still a noob dont mind me
Exar-Kun
Car: 2005 350Z
nils is running a 9" or 8.5" on the rear with some 255-40-17....
exactly what chris may ran.-chet
Nils
Car: road racing
Dmora.. wassup bro.. I remember you from SF. You sold your Supra or just adding a 240 to your stable?
10" wide rears with +41 offset I think... will only clear with coil overs, 5mm spacer and some minor fab work to the A arm. I also run severe negative camber.
If you are planning on doing track events go with a 17" wheel, less expensive wheels and tires and more choices of race tires in 17.. also lighter. For street go with 18's.. bling bling.
Here is a pick of the rear end with 10's (255/40 sticky Victoracers).....
n
Aries
Car: LT1 240SS
ah yes, I love the 10'sI have some welds in 11.5" widthe that I'm using for now as track wheels with 30x12.5x15 ET Drags :)
dmora
Nils wrote:Dmora.. wassup bro.. I remember you from SF. You sold your Supra or just adding a 240 to your stable?
[IM]http://to4r.com/240/track%20stuff/DSC00068.jpg[/IMG]
n
Hey Nils, nice to see ya here. :cool: I had to sell the Supra but i wanted to keep something sporty and RWD. I have to ask, but if you can fit a 10" wheel on the car, why in the world are you running a 255? The stock supra wheel at 9" with a 255/40 wheel looks like its stretched, i would have to imagine that a whole other inch would be even worse. a 10" wheel will hold a 275/35 tire quite nicely and have a nice side wall and have the whole tire foot print on the ground with out rolling or folding.
Nils
Car: road racing
I have tried larger rear tires and I prefer the 255's for the track. Just looking at them, they dont seem badly streched at all, fairly straight side walls.
n
dmora
Nils wrote:I have tried larger rear tires and I prefer the 255's for the track. Just looking at them, they dont seem badly streched at all, fairly straight side walls.
n
wierd.:confused: Anywho... Here are some photochops i made of a 240 i found, and slapped some of the fikses im interested in on it.
dmora
i really dont like that front end, it looks like a snow plow.
Nils
Car: road racing
I like the solid five spokes like Peter B uses alot.... yummm.
you can have them custom made, so I'm sure with a little more R&D you could fit a 10.5 or an 11" wide in the rear with a small spacer and the correct offset =)
btw - the 240 is an awsome handling car.. put a sr20det in it like I have along with an LSD and you are in for some serious fun... I actually like driving my 240 more than I did with the Supra =)
take care,n
Exar-Kun
Car: 2005 350Z
I like my gram lights :)
volk=good.fiske is nice...I'm with nils on the solid 5-spoke design.-chet
Nils
Car: road racing
Gram lights are sweet too =)
n
Nathan
I like the not so shiny five spoke ones...In Nathan's world...SHINY BAD...you should see my car...very un-shiny! ;D
bigE
The 5 spokes definitely.
Eric
C-Kwik
plastik240se wrote:Did you try out the 9" (you like?) or was it just a throw on while up on the rack or somthing:confused: :jet: love these smilys
It was actually on a friend's car. And I actually know two people who run them or used to run them. I run a 17x8 front and 17x9 rear.
