What's the largest size of tire u can put in an S13?
Beto-(S13)
Car: 92' 240SX (S13)
Without having to do some mods... what I'm interested in is in this: 235/50/16 measure.
boznuttz
Car: MS13
What is the wheel width and offset? What suspension components are you using?
...You need to be a little more specific. With the right wheel size and offset, you can run any size tire really. It's all about how flush you want them to look.
nismofly
Car: 89 Nissan 240SX Hatch
i have no idea where you found tires in that size but ive never seen it
you could fit 245/45/16 if you want, theyre much more common
Beto-(S13)
That tire size doesn't exist (I think) I was just using it as an example... I have a stock suspension. I was just wondering what tire size I could use without having fender rub and without instaling a widebody or whaterver... Thax for the info!!!
whiterps13
Car: white LE hatch
Broadfield is running 275/35/18's on the rear of his s13 with a roll, no pull.
