whiterps13 »
https://forums.nicoclub.com/whiterps13-u9007.html
Mon May 07, 2007 1:43 pm
Well you realize that both the width and the sidewall of the tire will be greater than what your currently running, right?
Width (mm)/ % of width / Diameter
Just making sure. But to answer your question, the car will behave differantly. The tires will be more ballooned on the rims, which does a couple of things for handling.
First, the car is going to ride slightly better due to the increased sidewall. It will absorb small bumps slightly better. Other than that, turn in and overall steering feel will be slightly sloppier due to the increased sidewall and shape of the contact patch. Although its not going to be a huge difference, you will notice it. Also, the tire will stick out 10mm on both sides of the wheels, so make sure you have enough strut clearance to accomidate this.
