What's the difference between S13 and S14 diff.???
Dugi
Car: dragging
I know the S14 diff will fit in the S13, but will it be worth it?? I mean is it any way better than the S13?? Just looking for a cheap upgrade to get better traction. Or are there any other diff that will fit the S13 but are better then the one in the S13??
thanks
Douglas
Nismo_Freak
Car: 89 Nissan 240SX
You're looking for a VLSD differential... and not all S14's had them.
There are mounting differences between the two diffs as well.
Dugi
Car: dragging
I thought the S13's came with the VLSD?? if not what do they come with?? is the VLSD better then the LSD?? I don't know much about diff. so that's why all these Q's.....
silkk
Car: 94 B13
89 S13
07 S2000
S13's came with VLSD and Open Diff. The fastbacks with Super HICAS came with VLSDs while the other s13's have open diffs.
Nismo_Freak
Dugi wrote:I thought the S13's came with the VLSD?? if not what do they come with?? is the VLSD better then the LSD?? I don't know much about diff. so that's why all these Q's.....
LSD = Limited Slip Differential
VLSD = Viscous Limited Slip Differential
They are inheriantly the same, the difference is mearly semantics as far as USDM differentials are concerned.
Nissan only used the viscous type of LSD in USDM R200's (Your differential = R200) It's called an R200 because of it's 200mm diameter ring gear.
Dugi
Car: dragging
ok thanks for clearing that up.. so which diff will be the best upgrade?? no aftermarket diff just OEM ones that will fit the S13.. I want a 2 way but those are very pricey and welding is another option but that would put too much stress on my axles...
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Read here, it may help:
http://www.KA24DEvelopment.com/vlsd.html
- Brian
