What's the difference between a Q45 and a Q45T???
carlosinseattle
Car: 94 Q45a 91 Q45 Base SOLD
I didn't find any definitive answer. If you can tell me I'd appreciate it. I guess I'm really asking what'st the "T" for? Why is that one different than a base model?
Yes.
The Touring model had a 15mm rear sway bar (none on the base Q), as well as some creature comforts (which Wes can probably detail better than I can).
Q45tech
Rear 15.9mm bar and front 28mm sway bar to shift roll stiffness ratio more rearward to reduce understeer. Rear is 12% stiffer and front is 5% softer.
And the dynamic [from steering wheel position and speed] adjustable rear toe which help turn in into a curve and stabilizes oversteer coming out of a curve.
When maintained and adjusted correctly significant improvement in feel and safety............valuable in wet conditions.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Later (1994+) Touring models also had heated seats and Sony 10 CD players.
1994 t model also had HICAS.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Rear trunk spoiler, no third brake ligh in rear deck, "t" badge on trunk spoiler next to "Q45". Lightweight 15 x 6.5" BBS wheels and beter tires.
Mine came with gaudy gold plated badges.
The heated seats are really nice, this time of year.
For some strange reason, my "t" did not come with the CD Changer.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Jeff Williams wrote:Rear trunk spoiler, no third brake ligh in rear deck, "t" badge on trunk spoiler next to "Q45". Lightweight 15 x 6.5" BBS wheels and beter tires.
Mine didnt either (CD changer), as it has a 6CD clarion instead of the crappy 10CD sony....
My T came with only heated seats... I know ive said that a lot of things came standard (creature comforts) with the T models, but you could get the T model AS WELL as one of the other packages.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
CD player must have been a 1995+ item as it is in sales brochure addendum for 1995 MY.
elwesso
2007 BMW M Coupe
UNless me an Jeff's Q had the sony and someone took it out becuase it was broken. I suppose thats reasonable to think.
