What's the dif? - Model year swaps for q Differentials
vroooooooom
Car: Q45
Looking for the diff-initive answer to the burning question, will any Q45 differential (90-05) fit my 1994 given the doner car does not have active suspension or TCS???
By the way, great site and ya'll are very knowledgeable.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
only 90-96 Q.....
rsiwicki
Car: 95 Q45T
If you have TCS then you need a TCS differential which are not cheap or easy to find.
Also from 90 to mid 91 diff's will not work either as there is something a little different with them that has to be modified to work. To be on the safe side be sure it is from a 1992~1996 car and watch the TCS vs. non-TCS stuff. Better yet...buy one from one of the Q's being parted out in the classifieds or go to car-parts.com and you will find several available.
elwesso
2007 BMW M Coupe
rsiwicki wrote:If you have TCS then you need a TCS differential which are not cheap or easy to find.
ahh yes thanks for bringing that up, i forgot about that!
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Slim was able to swap a complete Q45 rear and axles in his 300ZX non-turbo. The 300ZX axles are a little shorter, but might work in the Q.
Beter yet, maybe someone could try to swap the entire rear subframe from a 300ZX non-turbo.
elwesso
2007 BMW M Coupe
Jeff Williams wrote:Slim was able to swap a complete Q45 rear and axles in his 300ZX non-turbo. The 300ZX axles are a little shorter, but might work in the Q.
wont work, the subframe is a about 2in shorter..
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
wes, good info on the z32 na. what about full subframe from fy33 into g50?
i know i know-- i own both and should be the one to know, but i don't.
elwesso
2007 BMW M Coupe
see the other thread, Jay... BTW the stuff that I said was mostly speculation based on deductive reasoning!!!
redmanfx
Car: 92 Q45a
Jeff Williams wrote:Beter yet, maybe someone could try to swap the entire rear subframe from a 300ZX non-turbo.
Won't work. Been tried, it's too small.
