What's the deal with electric fans?
4felix20
Car: Emerald Blue S14
I've heard people say it makes them overheat and it helps out alot and all sorts of conflicting shiet. I deliver pizzas..so that means i sit in a lot of traffic and i was wondering if i got some dual 12" electric fans from enjuku, if i'd end up overheating. that's all i'm really worried about, cause it gets hot here.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i do believe whoever said the fans would make the car overheat is retarded. id buy them if youre worried about the car running too hot.
bruinbear714
4felix20 wrote:I've heard people say it makes them overheat and it helps out alot and all sorts of conflicting shiet. I deliver pizzas..so that means i sit in a lot of traffic and i was wondering if i got some dual 12" electric fans from enjuku, if i'd end up overheating. that's all i'm really worried about, cause it gets hot here.
It only overheats if you install it incorrectly. IE, with strain on the wires, eventually the connectors will fall off due to the amount of current and heat that it is exposed to and the fans will not come on.
Install it PROPERLY and you won't have a problem.
I've had mine for about a year now and no problems.
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
When you guys install the dual electric fans are you removing the mechanical fan on the motor, and if so are there any problems?
bruinbear714
240sxGT wrote:When you guys install the dual electric fans are you removing the mechanical fan on the motor, and if so are there any problems?
Take a look
Hijacker
Car: '92 240sx Convertible
'94 F-150
no point in having the belt driven fan if you're dropping some electrics in. Unless you mess up the installation of your new fans, there should be no problems and you'll probably enjoy the new 4 or 5 inches of clearance you just gained.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
and easy access for changing belts :)
Turb0wned
im thinking about getting an electric fan to can anyone tell me where, how much do they go for and, who makes a good one?
shane bigler
I heard 40 bucks at your regular auto parts store and they work just fine. No point in spending $$$$ on some fancy, costly, fan. I have yet to try.
Turb0wned
ok thanks
4felix20
dual fans from enjuku for around 200$. you pay for what you get.
BadMojo
Car: 2007 Mazdaspeed 3
I'm curious...what do you guys do for fan shrouds? I've read a variety of different solutions, none of them particularly appealing to me. I'd imagine that the shroud plays a big part in getting the air where you want it to go and keeping the engine nice and cool.
4felix20
if i get some fans, i'm gonna just take the shroud off. it's really only there to guide the air the clutch fan is pulling, since it doesn't sit right up next to the radiator.
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
just get used ones, I got dual 12" FAL's for 160 shipped.
