Bah.http://x.nissanhelp.com/forums/pathfinder/10491-low-oil-pressure-idle-05-pathfinder-le-4-0-60-000-miles-2.html#post41729 wrote:I just got off the phone with a master tech in virgina and this is what he told me.On two accounts, both on 05 Frontiers, with low oil pressure at ldle when completely warmed up...Root cause was a very small gasket located on the inter timing chain cover that is behind a "L" shaped steel cover on the right hand side.I looked this up and it is a bit hard to see but found it.Down side...No gasket in nissan parts catalog and no service bulletins has been issued.You have to replace the intire cover as a assy.at about $200.00 just for the part.Make sure all the test have been preformed before you have this done.
Thats not normal!...Seems very low. I would take it to the dealer and have it put in writing that it's normal...even if you have to pay the inspection fee.Here is a pic of mine with normal operating temp.I might of missed it, but how many miles do you have?n8guy wrote:Thanks, Pwnin'. I called and they said that it's "normal". I have a reference # now, too, in case something happens (although they refused to send their response to me in writing).
And Buzzman, good idea, although I don't know anyone with a Pathy of the same vintage. I may take it down to the dealership to have them check it out and possibly compare with a similar rig.
I suppose I have enough information to cautiously set this aside for now, ensuring I'm careful to keep an eye out for issues in the future. Thanks for your help, all.
Yeah, I'm an idiot and I completely forgot. Glad to see everything's working again!wizeguy wrote:That pic was taken after I cleaned my throttle body and had problems
n8guy wrote:So I took it in this morning and they ran the tests twice (just to be sure I guess?). They claim that the mechanical gauge reads within spec and consistent, even when the gauge drops.
They recommended a new oil pressure sending unit, referring to the gauge reading as being "all over the place". But I'm not sure it's that at all - in fact, it's dead-on reliable (as you can see from the video in this thread). I'm just not sure it's even worth replacing the part.
What do you guys/gals think? What are the chances it's the oil pressure sending unit going bad? Is it worth a replace? If so, where's the best/cheapest place to get the OEM part? $89 didn't seem like a very good part price (from the dealer).
I don't know, exactly. I asked the same question and he told me (and verified) that that's what's in the system. My best guess is that they can diagnose the problem by only removing up through the front cover - then they can see if oil is leaking through or the gasket is compromised. I know their plan would then be to replace the entire rear cover, not just the gasket, which was part of the quote, and something like a $250 part. Not sure the details, but that could be some insight.Pwnin O’Brien wrote:If they are going to charge you $600 in labor, which would require actually removing the front and rear timing chain case, then why would they charge you an additional $900 to install some $0.50 gaskets?
To my knowledge, there is no remaining warranty. I would suspect the dealership would have checked that, as well (although I'm not certain). The guy at the dealership did ask me if I had an extended warranty, so perhaps that was after verifying that I didn't have one otherwise.Pwnin O’Brien wrote:Is the vehicle not covered any longer under the bumper-to-bumper warranty? Is there any sort of warranty remaining on the vehicle?
Ok, so that option is out for me. I've done some work, but definitely not something that extensive. So that narrows the options to:Pwnin O’Brien wrote:Here's an idea of what is required in replacing the seals behind the rear timing chain case.
