You're talking about the large pop-off panel at the left end of the dash. I think he's talking about the blank switch space just to the right of the mirror control.Martin Roy wrote:As I said in the tutorial, it's an access panel, which allowes you to "easily" reach parts (harness, connectors, wires, bolts, ...) located behind or over the fuse box. There are a couple of places like this in the car.
Nissan fogs are controlled by the turn signal lever. When you buy the OEM kit, it comes with a new lever to replace the current one.matt_a wrote:Isn't that where Nissan mounts the switch for fog lights if you get them?
Drool... I know exactly what I'd put there... in every one of them... drool... think we can import that part ;oDCodeRed wrote:I found a picture of a Tiida that has a lot more empty slots.
The other aspect is pure aesthetics. The switch panel mount is about the width of the fuse access door; if it were sized for just the switches it'd be a bit narrower and might look a bit too skinny. Also, there's the symmetry... single switch, mirror controls, single switch (blank). Without the blank, the two switch sets remaining would look a bit unbalanced.motoguy128 wrote:I believe that switch cluster is a parts bin item for Nissan. I leaves room for a extra accessory. On our '06 Altima, the pwoer trunk release is in this location, but hte power mirrors are on the door.
