liquid_cool wrote:with a fresh rebuild..you should run the motor for about 2 hours..then dump all fluids..even the radiator fluid...after a rebuild you may have excess junk trapped in the system....dont forget to dump the filters as well...for the first 2000miles..use NON synthetic oils..to break things in..chepo oil works best...i have a habit of changing my oil several times throu out a break in..just to be safe..after your all broke in..then i would change to a more engine sustaining oils like torco,redline,royalpurple,or what ever floats your boat...but..i donot recomend the crap synthetics offered at say hellmart..some are a blend of recycled products..stick with the best and you will enjoy your ride for years.
Pretty much on the money here...
Also after changing that first set of oil and filters after your build...Crack open your oil filter to see if there is any small or large fragments of metal. If so, something went wrong and you should not drive it till the problem is corrected.
