showme »
https://forums.nicoclub.com/showme-u314051.html
Thu Nov 21, 2024 10:28 am
Working on my daughter's '04 Quest to get it ready to sell, I broke the oval center console into a couple of pieces. The thing was broken already by a previous owner (the vertical center piece between the vents and one place where the top 'bow' meets the bottom section), so I was attempting to get it out and fix it. I had the upper section out and found the PO had also busted off the screw mounts on the backside too. I figured it would be easier to pull the whole console faceplate and repair it off the dash. When I was disconnecting the wire connectors on back, the bow broke completely in two. I've seen dry rot and sun rot, but I've never seen anything on any car with such fragile plastic parts on this vehicle. Anyway, after checking on a new replacement part and seeing the exorbitant price for a plastic part for a 20-year-old vehicle, and since she's selling it, I'm just going to glue it together and put it back in and let it go. Like I said, it was broke when she got it and it's 20 years old. But I'd rather not sell it looking like it's been damaged. So!
I'm pretty sure I'm not the first one to have this problem (actually, two problems- the little plastic 'keeper' that you have to lift to get the stick shift off broke off while I was 'slightly lifting it'). What adhesive will work on this material and stay put? I have some JB Weld Plastic Repair stuff that's a dual mix epoxy that I tried on the center strip, but it wouldn't hold and it took forever to set up. I've read that Rhino Glue Gel, Heavy Duty is good, but I'd like to see what everybody here as done when this occurred. Any and all suggestions or ideas would be greatly appreciated. Lee
