what's that part #?
franknitty69
Car: 1995 Infiniti Q45a
hello,
i have a pic of a suspension part and i wish to order it from joe. it is from a 95 q45 w/active suspension. it appears to be listed as #12 sensor connecting rod in the FSM
it connects the lower link??? to the rear height sensor.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
what page is that from the FSM. that will help me find the P/N.
franknitty69
there is a picuture on FA-35 and FA-47.
Q45tech
Ride height adjustable sensor assembly..................the potentiometer reports a voltage to active ecu relative to position.
The arm moves only <<<+- 1.0 inches when the wheel moves +- 4.0 inches up and down.
You set the threads to level [set the ride height] ..........like toe even 1 full turn is a noticeable effect, as shipped should be close.
franknitty69
q45tech, that is correct; but whats the part #. i've called several infiniti dealers and they can't find it based off the description i give them.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Frank, have them start with the rear height sensor, and then they should see the linkage from the sensor in the same section drawing.sorry, cant help with the actual p/n. If you totally strike out, i know someone who still has one on his converted active that we could maybe poach.
franknitty69
they've found the part but its on back order. Jay any chance that you might still have this part?
thanks
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Ahmed, I got your e-mail. I don't have a spare of that part.suggestions:1. contact redmanfx and/or texasoil. they might have it straight away.2. go ahead and order the backordered part. I've never struckout on a b/o part (as long as it does not trigger 'obsolete' in the system), longest i've had to wait is 1 month for part to come on slow boat from Japan. Typical for active stuff is about 2 weeks from IoS.3. Ask tkd_q45 if you can have one of his. if he says ok, then next time i see him i'll pull it off his car.
Jay
